ford 8n hydraulic valve sticking
gac1218
If the hydraulic pump valves are sticking, do they have to be replaced or can they just be cleaned?
What kit do I need if I am dropping the pump?
Should I rebuild it while it is out?
Hang in there--1000 different opinions await
you....NO, I wouldn't rebuild it..I'd clean it good,
clean the sump out and let her rip-----if it was
lifting good and not knocking bad..
his last post on this was page 3.
NOT lifing.
no overhead oil leaks.
rod moving for and aft.
I'm thinking intake not opening.
