distributor
Anonymous-0
OK? my front distributor on my 8n "early model" i took the cap off and turned over the motor with the starter,,,,, but the rotor just turned a little , maybee 1/4 of a turn and them stopped and then moved again, all while i was turning the motor over? bad distributor? or broke inside? like the timing gear?
thanks
(quoted from post at 18:58:48 04/11/14) OK? my front distributor on my 8n "early model" i took the cap off and turned over the motor with the starter,,,,, but the rotor just turned a little , maybee 1/4 of a turn and them stopped and then moved again, all while i was turning the motor over? bad distributor? or broke inside? like the timing gear?
thanks
wo bolts & it is off & you can look & see, or we can all guess.
Unsnap the cap on the dist. Let er dangle (sorry Dell) Take the two bolts out that hold the dist. in and tell us what you find.
