Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Starter just spins
JMOR
04-07-2014 09:29:31
Quoting Removed, click Modern View to seeBruce is correct. ...and you are correct in that if you want to deliver the same power, you could design for double the voltage & half the current. How does double the current get through smaller cables? Allow me a parallel..........a 12GA wire is nominally rated for about 20-35 amperes, BUT it will carry over 200Amperes........for a short period just before becoming liquid. Wattage out of batteries? Yes, the battery will ultimately limit that, but far before that limit, the load will set the wattage. P(Wattage)=EI, I=E/R, then P=ExE/R.
Double E (2E), then P =2Ex2E/R=4E/R, hence, 4X the power by doubling voltage. HTH
Copyright © 1997-2015 Yesterday's Tractor Co.
