Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Lift cylinder question
OBwan
04-07-2014 08:13:41
I was in a similar situation last October. Cylinder had a steady leak and after tear down a deep scratch. I bought the aftermarket cylinder, the NAA piston and I am satisfied with the results. As you stated I did need to grind the scallop per Tim Daley"s write up. It took all of ten minutes and that"s with me working very slowly and deliberately. I also needed to touch up one of the bolt hole surfaces so the bolt head would sit flush on the cylinder. The cylinders are pretty thick and not as tapered as the originals. All in all not a big deal. Here are some of my references.
The How to Repair Economically by Tim Daley and the Hydraulic Troubleshooting from Zane Sherman.
mike-ga
04-07-2014 08:48:55
 Re: Lift cylinder question in reply to OBwan, 04-07-2014 08:13:41
Thanks, I have read your article 3 times, great article. I have honed the cylinder out and with advice from a local mechanic may try my cylinder. If nothing else, maybe it will leak down alot slower :). Just wanted to get a guru's thoughts.
OBwan
04-07-2014 09:27:59
 Re: Lift cylinder question in reply to mike-ga, 04-07-2014 08:48:55
Those two guys aren't me. I'm not at their level. I did stay at a Holiday Inn Express recently....
My feeling were to do it all while I had it out rather than piecemeal it and then have to take it off again later when it didn't work right.
