TractorLinks.com
Order Ford 8N Parts Online
Re: 1950 8n jubilee
maxwell99
04-07-2014 00:16:29
Does the tractor set outside?
If so, maybe rain is getting into the air intake hole, some part may be missing. Many old tractors never see the inside of a barn.
My old tractor has a rubber horn shaped air scoop that fits under the dash then across to the air cleaner. The hood protect it from rain water.
Has someone washed the tractor and maybe got water up in this area with a pressure hose?
How often do you have to check the oil bath for water contaminantation.
This could be a very serious problem if you were to suck water into a hot engine.
Finding the water leak should be a top priority.
Let us know what you find, or post pictures of your air cleaner.
Dave Carlson
04-08-2014 17:18:39
 Re: 1950 8n jubilee in reply to maxwell99, 04-07-2014 00:16:29
Thank you all for your insight and help. Yes, the Jubilee is a 1953 but i will check the id numbers to be sure. Thanks especially Maxwell99 and Bruce. You all have given good insight and i will be back with the next chapter after i get out with the Jubilee again next week. i will follow up on the thoughts you gave. Dave
