Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Lift arm Welding ?
04-06-2014 19:54:53
rule of thumb..electrode dia. should be the thickness of material to be welded..1/8 is usually used, except in fab shops
04-06-2014 22:56:17
 Re: Lift arm Welding ? in reply to pconnie, 04-06-2014 19:54:53
So what you are saying is that if I am welding a piece of 1/2 inch metal the rod should be a 1/2 inch diameter ?
What you say about 1/8 is usually used except in fab shops is bogus. Doesn't make sense.
As a retired certified welder I find the info you are stating is not correct.
Run a 6010 pass on it, then cover with 7018. Just saying.
04-07-2014 10:10:58
 Re: Lift arm Welding ? in reply to Sycamorecreek, 04-06-2014 22:56:17
if welding in ship mfg. or similar fab. they match rod with mat. hardly seen any more except for repair. keeps from multiple passes.
fab shops usually have a range of electrode to match jobs.
dont know what you did. i sold electrode to all facets of welding repair ind.
why 6010 as root pass?
Dave8N in Pa
04-07-2014 15:15:57
 Re: Lift arm Welding ? in reply to pconnie, 04-07-2014 10:10:58
He said he has a buss box. Is it AC/DC? Maybe just AC and he doesn't sound like he's done a lot of welding. 6010 is makes a good root pass if he has a DC welder. If only AC he needs 6011. 7018 is normally DC but you can get 7018 for AC. If he is a beginner he will not know how to whip quick-freeze rod to do a proper root anyway. For a beginner 7014 will work much easier and he will learn with experience. Good rods for beginners are 6011 and 7014. A single bevel will give him enough to fill and it will work just fine. 1/8 rod is a good size to learn with.
