Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: cotter pin port on 8N
Mr. T. Minnesota
04-06-2014 16:20:20
Bruce, I checked the fluid that came out and have a feeling it is the engine seal. I have never taken apart an N tractor. Any basic hints for the novice that are not covered in the manual? If taken apart I want to check the oil pump too, it does not hold a decent pressure when hot. Any additional thoughts are welcome.
Mr. T. Minnesota
Bruce (VA)
04-06-2014 17:39:21
 Re: cotter pin port on 8N in reply to Mr. T. Minnesota, 04-06-2014 16:20:20
As others are telling you, I'd leave it be until it shows up on the dipstick. Just park it on level ground!
What kind of oil pressure do you have?
Unfortunately, a worn pump is not the usual cause of low oil pressure; it's worn bearings.
Jimmyjack
04-06-2014 17:10:41
If its not a steady occurance I wouldnt get too excited yet. Mine does that once in a while when I load it on the trailer. Suspect that the angle when loading it causes some puddling to run out.
Bill Crowell
04-07-2014 07:29:35
 Re: cotter pin port on 8N in reply to Jimmyjack, 04-06-2014 17:10:41
It's a good thing that your 8N leaks oil because you won't have to kill the weeds where you park it.
Copyright © 1997-2015 Yesterday's Tractor Co.
