TractorLinks.com
Show Parts for Model:
Re: tie rods too short
chris in oregon ohio
04-06-2014 15:50:42
with hub at 3 oclock position keyway points to 10 oclock that makes it a right side.if keyway points to8 oclock its a left side.thats what i was told
John Smith8N
04-06-2014 17:30:22
 Re: tie rods too short in reply to chris in oregon ohio, 04-06-2014 15:50:42
If you have original unmolested 9N drag links then your steering gear is likely out of time. If you have non original drag links that's another can of worms. Easy to check the steering box. Turn the steering wheel so the arm on one side points directly at the radius rod ball socket. Then look at the other side and see if the arm on that side is also pointing in the general direction of the radius rod ball socket. If so, the gear is in time. If not, it's a tooth or more off and will need to be retimed. If you had the original 9N spindles and arms before and the arms had been welded in place, they were probably welded in the wrong position and the previous owner modified the tie rods to fit or jumped the steering gears until they fit.
John Smith8N
04-06-2014 17:14:21
That's right. If you had the spindles on the wrong sides your tie rods would be too long, not too short.
