Nuetral safety mechanism
jds535
Hi Guys,
I have a 41 9n. Whoever had it before me eliminated the nuetral safety starting Mechanism and added a newer solenoid. They must have had problems with it because when I removed the starter button, they had added washers under the starter button trying to get more throw out of the rod. It didn't work.
I bought a new solenoid switch ( from this site , under 9N parts ) and it doesn't work. When I removed it I can see that the push rod does not have enough throw to activate the button. Does anybody sell the little flipper and push rod new?? I can't find it anywhere. I thought maybe the parts are just worn and loose.
Is it possible I just bought the wrong solenoid? The one I bought is 1 5/8" from the bolting plate to the end of the button. Seems about a 1/4" short.
Thanks, Jeff
The after market switches were made wrong. the end of them is con caved a little and they should have a protrusion to give them enough length to work. I have been in touch with Tisco and they are supposed to be getting them corrected but I haven't seen any of the new ones yet.
Mark
Sounds like you have it figured out as to what they did.
If your linkage actually works, you may be able to add a washer
to the end of your new switch and make it work too.
I don't know if anyone sells the parts new, but good used ones
are probably still around. Maybe John Smith or Jim.UT would have
what you need. For that matter, I might have. If enough snow melts
this weekend I'll go out and look on a tractor I have out back.
The actuator buttons do get gunked up inside and lose travel. Take it off and soak it in a pan of solvent for a while, then work it several times and keep rinsing it to get it cleaned out. That may give you back the extra stroke it needs to make the switch. It's worth a try.
Hi Guys, thanks for the feedback.
I had everything apart including the entire top cover. Everything is clean and working freely.
The button works well.
I thought about adding some weld to the end of the push rod to " pre-press " the switch halfway if I cant find new parts??
Thanks, Jeff
(quoted from post at 03:43:26 03/28/14) Hi Guys, thanks for the feedback.
Thanks, Jeff
weld would work, though kinda permanent.
I'd drill and tap either the rod or the switch and
thread in a short bolt. The bolt head should take up the space.
(and it's adjustable)
(quoted from post at 21:54:14 03/27/14) Hi Guys,
Thanks, Jeff
