TOH valve job?
Hello Mr. Hokie. I was wondering if you have the abilty to grind valve seats down there. I plan to get the valve kit to replace all the other parts, but the exhaust seats are badly pitted. I am also interested in your sleeve tools. I should stop down there one day, I just need to find the time. Thanks Justin
(quoted from post at 18:03:21 03/26/14) Hello Mr. Hokie. I was wondering if you have the abilty to grind valve seats down there. I plan to get the valve kit to replace all the other parts, but the exhaust seats are badly pitted. I am also interested in your sleeve tools. I should stop down there one day, I just need to find the time. Thanks Justin
Nope - no valve grinding capability. By all means - do drop in. Better call first to make sure I will be around.
TOH
If the seats are very badly pitted,it may be better to install new ones. Then grind the valves to their correct geometry,lap and go! lha
(quoted from post at 05:08:12 03/28/14) If the seats are very badly pitted,it may be better to install new ones. Then grind the valves to their correct geometry,lap and go! lha
Thanks for the info. As much as I like to do things myself, I talked to my local machinist and I'm gonna have him look at the seats (he said the same thing) and also cook it and check for cracks.
