bendix pin is impossible
cbradio
im about to loose it.
i cant figure out how to get the pin in there. i could have my entire body weight on a set of pliers adn i cant pull the metal ring down far enough to get the pin in.
suggestions?
I use a vise to squeeze it down enough to install the pin in one side and then slide the drive onto the starter shaft and tap the pin through with a hammer.
Mark
As below, easy, except for the hard part ! Good advise. Hey, if it was easy, anyone could do it ! Me, I'd get my secretary on it.
i do the old upside down trick using a vice. spread the jaws to capture the disc.. press down on starter.. hole uncovered.. slip pin in.
I find that the easiest part of working on one..
