Ford 9n overheating
Farmer Kevin
New User
Hi I have a 9n with a new water pump,belt,hoses and
thermostat it over heats after very little use n is y I changed the
pump. Any ideas on as to y is still over heating would be I
appreciated. And yes the thermostat is put in the right way the
belt is tight and coolant it is up to level and not going down
Check out tip # 24 at the link.
But, sometimes you just have to bite the bullet & flush out the block & radiator. To do that, remove the t-stat from the top hose. Then, remove the bottom hose from the radiator & stick your garden hose in the radiator. Turn the water on (reverse flush) & the water will flow into the radiator, then the block & out of the disconnected lower hose. Let it run until the water is clear. Then, check the radiator flow. Stick the hose in the top of the radiator; the water should flow out of the bottom w/o backing up in the filler neck. It should flow at 19.5 gallons a minute. As a final flush, put a gallon of white vinegar & about 2 gallons of water in the radiator, run it to operating temp & then drain it again. Don’t forget to put the t-stat back in correctly!
Use 50/50 anti-freeze & distilled water as your coolant. The anti-freeze contains rust inhibitors, pump lubricant & raises the boiling point of the coolant.
If you do need to get the radiator re-cored, make sure you get the flat fin industrial core. Automotive style cores will clog up w/ debris very quickly.
75 Tips
As below, you should think about flushing EVERTHING. I got about 1/2 an ice cream bucket (4l) full of apcray out of my 45 2N block alone. HTH
Kevin,I have seen the blocks on Ns be 1/2-3/4 full of rust,crud,and old stop leak.You can remove both hoses from the engine,remove the drain cock from the block.Then flush it out with a water hose turned on full alternating from upper to lower with a rag wrapped around the hose for a good fit.run a wire into the block drain hole to loosen crud. If it still has crud in the block find a 1/4" npt male garden hose coupling and hook the hose to the block to flush it out.Then flush the radiator out.Then run some vinegar in it and flush again.
deffinately flush block, then see how well the rad passes water from inlet to outlet.
lastly.. not running lean are you?
and have you done a leakdown and compression check?
