TractorLinks.com
Order Ford 8N Parts Online
Re: 8n hydraulics
Bruce (VA)
02-18-2014 16:08:19
" what are the part numbers i will need"
That would depend on what's causing the problem.
You must have missed this part of tip # 16:
You probably have a worn lift cylinder or piston (or both), a blown top cover gasket or a leaky pressure relief valve.
Of course, if you just want to replace everything w/o diagnosing the problem, then you will need a relief valve, piston, cylinder & gaskets.
And while you're in there, you might just as well adjust the internal linkage.
You'll need a jig for that.
