TractorLinks.com
Order Ford 8N Parts Online
Re: 8n hydraulics
shane12970
02-18-2014 14:50:25
what are the part numbers i will need...Hydraulic Lift Piston and parts listed with it?
This post was edited by shane12970 at 14:52:31 02/18/14.
old
02-18-2014 16:57:38
 Re: 8n hydraulics in reply to shane12970, 02-18-2014 14:50:25
Trouble shoot first then worry about parts. This site sells them but I do not know the numbers off the top of my head
Bruce (VA)
02-18-2014 16:08:19
" what are the part numbers i will need"
That would depend on what's causing the problem.
You must have missed this part of tip # 16:
You probably have a worn lift cylinder or piston (or both), a blown top cover gasket or a leaky pressure relief valve.
Of course, if you just want to replace everything w/o diagnosing the problem, then you will need a relief valve, piston, cylinder & gaskets.
And while you're in there, you might just as well adjust the internal linkage.
You'll need a jig for that.
