Yesterday's Tractor Co. Compare our Prices For Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Some info on different clutches and types of pto - pics
Ultradog MN
02-18-2014 13:31:51
174.20.239.172
A couple of questions get asked from time to time about the different types of PTO.
So while I was working on a tractor here I thought I would snap a couple of photos and give some info on how they work.
We are all familiar with a tractor with transmission pto so I wont go into that type here.
There are two types of "live" pto.
Both are accomplished by means of dual input shafts into the transmission.
The outer, larger splined shaft is the pto input shaft.
The smaller one drives the transmission and rear wheels. This is the same on both "live" and "independent" ptos.
The difference is in the clutch. (And what lies behind the tranny which I wont go into here.)
This photo is of an independent pto clutch.
Notice the splined hub in the center.
This hub is rivited directly to the back of the pressure plate. So any time the engine is turning it is transmitting power to the outer input shaft, through the tranny to the pto.
Here is the back side of that same clutch.
On a "Live" PTO machine the dual input shafts are about the same. But the pressure plate contains TWO clutch discs. When you press the pedal down half way the main drive clutch disc is disconnected and the tractor stops forward motion.
But the pto continues to turn.
Then when you push the pedal all the way down the pto clutch disc is released and the pto also stops turning.
Here is a photo of a Live pto clutch with the two discs.
It is much more complicated than either transmission or independent pto clutches and thus considerably more expensive.
You can see the large hub in the pto disc.
Here is a photo of both types of clutches side by side.
A lot of times people get these two types confused or maybe don't understand how they work so while I had the parts here I thought I'd make a post about it.
[Reply]   [No Email]
Kurt-NEPA
02-19-2014 05:08:24
70.44.176.213
 Re: Some info on different clutches and types of pto - pics in reply to Ultradog MN, 02-18-2014 13:31:51
I was thinking the same thing Ultradog. The way yours work is not obvious. In fact I can't see the smaller splined hub in either one of your clutches. Mine is there behind the larger one, but hard to see.
[Reply]  [No Email]
Ultradog MN
02-19-2014 05:20:03
174.20.239.172
 Re: Some info on different clutches and types of pto - pics in reply to Kurt-NEPA, 02-19-2014 05:08:24
You can't see them cause they aren't there :)
I just snapped photos of the PPs
I figured everyone understood how the drive clutch works and focused on the secondary/pto output.
By the way, those sure are pretty pink springs on yours. I'm jealous.
[Reply]  [No Email]
Colin King
02-18-2014 18:31:41
67.233.242.237
Great photo tutorial! Thanks, UD.
Colin, MN
[Reply]  [No Email]
Kurt-NEPA
02-18-2014 15:22:51
70.44.176.213
Bill, your 861 clutch should be exactly like my photos above. Might be minor differences in the clutch but very similar.
Actually replacing this clutch is straightforward. Just expensive
[Reply]  [No Email]
Kurt-NEPA
02-18-2014 15:20:32
70.44.176.213
Sure did replace the seals Ultradog. That and the destroyed clutch, throw-out bearing, fork and TO bearing housing. Fun split. Had to cut off the fork and make a new pin.
BTW, the seal was leaking badly. What a mess.
[Reply]  [No Email]
Kurt-NEPA
02-18-2014 13:58:23
70.44.176.213
Good idea UD, A few pictures really help.
Here are some from a hundred series double clutch. A bit different.
Clutch with two sets of forks, each set at a different height.
[URL=http://s556.photobucket.com/user/kdmoser/media/Ford%20660/TiscoClutchinPlace.jpg.html][/URL]
Input Shaft
[URL=http://s556.photobucket.com/user/kdmoser/media/Ford%20660/660InputShaft_zps9cccc2d7.jpg.html][/URL]
Input Shaft taken apart
[URL=http://s556.photobucket.com/user/kdmoser/media/Ford%20660/DoubleInputShaftApart_zps247e22e2-1.jpg.html][/URL]
[Reply]  [No Email]
Ultradog MN
02-19-2014 04:16:43
174.20.239.172
 Re: Some info on different clutches and types of pto - pics in reply to Kurt-NEPA, 02-18-2014 13:58:23
Looking at your clutch again this AM it is very revealing how it works with the two sets of fingers. It is much easier to understand than the one I posted which is all done internally.
[Reply]  [No Email]
Hobo,NC
02-19-2014 04:56:18
98.17.179.44
 Re: Some info on different clutches and types of pto - pics in reply to Ultradog MN, 02-19-2014 04:16:43
I don't know what good it will ever do me... If I remove a known good unit I make tools to measure it bolted to the flywheel for finger height reference later on down the road...
[Reply]  [No Email]
BillM (OH)
02-18-2014 14:53:24
173.81.87.223
Not sure which one is on our 861 - have never had it apart.
Nice to have live PTO and live hydraulics!
[Reply]  [No Email]
Ultradog MN
02-18-2014 14:49:36
174.20.239.172
Really good photos Kurt.
I assume you had it apart to replace seals?
[Reply]  [No Email]
pikewi
02-18-2014 13:50:51
72.171.24.186
Good info. Thanks. I had kind of a vague idea of the differences between the two. Your post shed some light.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
