Yesterday's Tractor Co. Trusted Parts Supplier since 1995
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
8n hydraulics
shane12970
02-18-2014 12:07:12
70.193.139.221
I just bough a ford 8n.. the hydraulics pick up good and strong.. but when you depress clutch they drop pretty fast . is this normal? any suggestions.. Thanks in advance Shane
[Reply]   [No Email]
Dollar Bill
02-26-2014 03:21:25
98.70.214.72
 Re: 8n hydraulics in reply to shane12970, 02-18-2014 12:07:12
JMOR drew this most excellent diagram to show the nine potential leak points - Check with side cover removed; lift loaded and elevated, and engine off. As others have indicated, eight is the most common leak point.
[Reply]  [No Email]
shane12970
02-28-2014 10:00:53
70.193.68.214
 Re: 8n hydraulics in reply to Dollar Bill, 02-26-2014 03:21:25
Wow thats great i just saw this .. thank you gonna try to look this weekend ... will ost what i find
[Reply]  [No Email]
soundguy
02-19-2014 06:49:01
184.240.104.249
observe and find leaks before taking things apart and buying parts!
[Reply]  [No Email]
shane12970
02-25-2014 08:34:29
70.193.67.246
 Re: 8n hydraulics in reply to soundguy, 02-19-2014 06:49:01
still havnt had chance to look at.. it was low on fluid... i see no leaks on ground... where on tractor its self( not inside)
should i look for leaks..
This post was edited by shane12970 at 08:35:33 02/25/14.
[Reply]  [No Email]
soundguy
02-25-2014 09:00:14
184.240.26.44
 Re: 8n hydraulics in reply to shane12970, 02-25-2014 08:34:29
INTERNAL leaks...
[Reply]  [No Email]
TOM N MS
02-18-2014 18:20:30
172.6.29.244
Also might be leaking pressure safety relief valve..Had one that dropped so fast, the implement would be on the ground before you could clutch it and shift gears.--it was bad PSRV--look for turbulence down low in the oil once you have checked up above around the hyd. cylinder and other places above oil level..
[Reply]  [No Email]
shane12970
02-18-2014 19:17:34
70.193.139.221
 Re: 8n hydraulics in reply to TOM N MS, 02-18-2014 18:20:30
yeah i get ahead of myself... will look at it this week end thanks all..
[Reply]  [No Email]
shane12970
02-18-2014 16:07:56
70.193.139.221
i got it thanks guys
[Reply]  [No Email]
old
02-18-2014 13:42:20
209.86.226.59
Is it normal well yes on an old tractor that needs some TLC. Is it correct no and as others have said good chance it has a leaking cylinder rings. Pull the inspection cover off the right side start it up and watch for oil dripping. You may find you need to rebuild the lift cylinder and if you do it is best to replace with the new improved NAA type piston and rings
[Reply]  [No Email]
shane12970
02-18-2014 14:50:25
70.193.139.221
 Re: 8n hydraulics in reply to old, 02-18-2014 13:42:20
what are the part numbers i will need...Hydraulic Lift Piston and parts listed with it?
This post was edited by shane12970 at 14:52:31 02/18/14.
[Reply]  [No Email]
old
02-18-2014 16:57:38
209.86.226.40
 Re: 8n hydraulics in reply to shane12970, 02-18-2014 14:50:25
Trouble shoot first then worry about parts. This site sells them but I do not know the numbers off the top of my head
[Reply]  [No Email]
Bruce (VA)
02-18-2014 16:08:19
24.125.183.11
" what are the part numbers i will need"
That would depend on what's causing the problem.
You must have missed this part of tip # 16:
You probably have a worn lift cylinder or piston (or both), a blown top cover gasket or a leaky pressure relief valve.
Of course, if you just want to replace everything w/o diagnosing the problem, then you will need a relief valve, piston, cylinder & gaskets.
And while you're in there, you might just as well adjust the internal linkage.
You'll need a jig for that.
[Reply]  [No Email]
Bruce (VA)
02-18-2014 12:22:09
24.125.183.11
" is this normal?"
No.
Check out tip # 16 at the link.
As well as tip # 39.
Congrats on the new tractor.
[Reply]  [No Email]
R Geiger
02-18-2014 12:19:52
50.39.141.219
 Re: 8n hydraulics in reply to old, 02-18-2014 12:07:12
It usually mean the piston is leaking fluid past it, but if it doing what you want it to do, why worry. If you want bragging rights about how long it will stay up, then fix it.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
