TractorLinks.com
Show Parts for Model:
Re: Ford 2 N Ignition
Bruce (VA)
02-18-2014 11:50:30
" Has anyone else had this kind of a problem ?"
Of course. It's such a common problem that it is tip # 38 at the link below.
What is uncommon in your case is going to be the cost to replace that EI.
If you leave the key on & the points are closed, you melt the points & probably the coil. Thatís a $40 mistake. If you leave the key on w/ EI, thatís a $150 mistake.
Post back w/ the tractors voltage (6v or 12v) & the make/model of the EI. Some of them have a fuse to prevent it from melting w/ too much current.
soundguy
02-18-2014 12:02:17
 Re: Ford 2 N Ignition in reply to Bruce (VA), 02-18-2014 11:50:30
hopefully he has the gen 2 ei.. if htere is one for the front mount.
gen 2 are smart enough to turn the power off if no revs after a while.
with a no run situation.. I'm guessing a gen 1
