My NH LS150 skid steer will drain the battery when setting for a month or so to the point it won't start. I measure 12.6v on the battery when charged and 11.5v between the loose neg cable and the neg battery terminal. Yet, I measure no current flow (using my cheap meter) between the cable and terminal on any of the amp scales!
Does anybody have a handle on the expected current flow from electronics on a unit like this while sitting? Presently, I just disconnect the battery cable when sitting but that is a pain to remove the panels, etc.
I know if there is a voltage differential there must be some current flow!
