POPGUN
Anyone put in a new Lower Link Support Shaft aska Pin? part# NCA563C. It is not like the OEM. It will wedge itself into the casting as tighten and the original castellated nut will not fit and will needed to be replaced with a larger one.
I went through that last summer. The old pins had 5/8" fine thread and the new ones are 3/4" fine thread. I was unable to get the 3/4" fine thread castle nuts, so I just cleaned the bore real good, installed the new pins, and just installed grade 8 3/4" fine thread regular nuts with thread lock.
Well got it in Chuck, used to thick of washer so cotter pin wouldn"t line up -new washer did the trick. Put the trumpet back on and good to go.
I did like it a bunch but just time consuming had to us the engine hoist its to heavy for 1 person to deal with. Let ya know on the flip flop.
