TractorLinks.com
Order Ford 8N Parts Online
Re: A burping 8N
old
02-17-2014 11:33:49
Give this a try. Take a quart of ATF and pour it into a gallon of gas and run it with that. If you already have a good bit of gas in it then use that and add as much ATF to it to bring it close to that mix and run it. If it has sticking valves or carbon that should clear up the problem
ASEguy
02-18-2014 03:39:37
 Re: A burping 8N in reply to old, 02-17-2014 11:33:49
Went to a seminar on biodiesel several years ago. The conversation worked its way to putting tranny fluid in a Powerstroke. The instructor said when they pulled the head on that engine the combustion chamber looked like it had been power washed on all cylinders. Apparently they were testing the effects of different types of "fuels" for diesels. This tranny fluid was used, but filtered, from waste.
old
02-18-2014 07:53:11
 Re: A burping 8N in reply to ASEguy, 02-18-2014 03:39:37
Yep ATF will clean up things and free up sticking parts real well guess that is why I keep saying to people they should use the stuff. Shoot I have an old pumper oil can I use that has ATF in it
JCinKY
02-18-2014 08:03:07
 Re: A burping 8N in reply to old, 02-18-2014 07:53:11
I love the stuff, and Old you turned me on to it. I haven't bought any PB Blaster in a year or so.
I buy cheap Type F ATF at Wally World and mix if about 60/40 with lacquer thinner. It is my go to penetrating fluid, valve unsticker, multi-use product.
Put it in a spray bottle, shake and go...
old
02-18-2014 08:14:25
 Re: A burping 8N in reply to JCinKY, 02-18-2014 08:03:07
Ya funny how when I first joined Y-T and said things about ATF and had people tell me I was dump and stupid and it did not work but 10 plus years later well people have found out it does work well
anvilheadtexas
02-17-2014 13:24:20
Old... thank you. Not sure what ATF is? Some gas treatment yes?
old
02-17-2014 13:41:45
 Re: A burping 8N in reply to anvilheadtexas, 02-17-2014 13:24:20
Guess you do not read many of my posts. ATF is something I have talked about for over a decade on here. Yep transmission fluid is ATF Dextron 3 is what I use
anvilheadtexas
02-17-2014 14:15:28
 Re: A burping 8N in reply to old, 02-17-2014 13:41:45
Old... have not prowled in a long time... but I do recall your suggestions always had some good sense behind them... I will try it.
old
02-17-2014 15:29:24
 Re: A burping 8N in reply to anvilheadtexas, 02-17-2014 14:15:28
Next time your in a store that has Marvel Mystery oil pick up a can of it and read what it is used for. Then use ATF in its place. ATF does the same thing as MMO but at half the cost
anvilheadtexas
02-17-2014 16:47:02
 Re: A burping 8N in reply to old, 02-17-2014 15:29:24
Yes, but does it smell as good!!! Haha! Thank you. I am restoring a Farmall Cub in my garage here in Houston. My sick 8N is up at my land an hour and a half from here...which makes trying all these very good tips tough...cause I have to wait to go up there on weekend. I want to bring the 8N home to give it the full once over... but last time I had my 16 foot trailer in Houston...someone stole it!
old
02-17-2014 18:53:39
 Re: A burping 8N in reply to anvilheadtexas, 02-17-2014 16:47:02
Ya I could not handle having to keep a tractor away from my place of living. As for a cub BTDT and did one for a friend a few years back. As for the MMO and ATF ya the ATF does not smell as good but for half the cost I can sure as heck live with out the good smell. LOL
Tom Jubilee
02-17-2014 17:24:47
Thieves in Houston? Don't send them my way!!
JCinKY
02-17-2014 13:36:43
Automatic Transmission Fluid; does the same job as Marvel Mystery Oil (MMO) without the price.
It is a solvent and will keep everything clean and deposit free. Add about a cup to every 10 gal of gas. I add some everytime I fill up.
anvilheadtexas
02-17-2014 14:17:18
 Re: A burping 8N in reply to JCinKY, 02-17-2014 13:36:43
I did add a little Marvel when I refilled the gas tank (4 gallons only) with fresh fuel....
What is the accepted ratio of marvel or transmission fluid to gas for an 8N?
