Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
stuck clutch
stan in wash
02-17-2014 08:28:37
76.28.189.189
Have 51 8N with a stuck clutch. Could use a few tricks out there to free it up. Tractor sat for a couple of years. It runs fine. Thanks
[Reply]   [No Email]
HCooke
02-17-2014 12:16:30
70.195.64.124
 Re: stuck clutch in reply to stan in wash, 02-17-2014 08:28:37
Once you get it unstuck keep it that way by blocking it down when you park it.
[Reply]  [No Email]
mhb@ufe
02-17-2014 11:07:08
24.39.22.34
If you have good brakes on the tractor and a safe place to do it, start the tractor and work it up through the gears. Once in high gear hold the clutch down and jump on the brakes. The shock load of jumping on the brakes has worked very good for me.
Mark
[Reply]  [No Email]
old
02-17-2014 09:25:07
209.86.226.30
#1 block the clutch pedal down when parked.
#2 if you can do so safely fire it up in the highest gear you can and hold the pedal down and drive it till it frees up. #3 pull the starter off and spray the clutch with brake cleaner spray with the clutch blocked down and turn the engine as as to get to it whole clutch. Or option #4 split the tractor and take the clutch apart
[Reply]  [No Email]
pconnie..ks.
02-17-2014 09:22:46
70.195.2.173
the last 8n i bought had a stuck clutch..blocked it down piece of 1x 3 works good on clutch lever ..drove it around until it freed..one other i have i had to back it up to a tree..once free i sprayed brake cleaner in the bell housing hole where the cotter key sticks thru..dont remove it ..keep the clutch blocked ..eventually the rust will wear off..but keep the clutch blocked..hth..phil
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
