Pie Weights for contacting Dean
J.Walters
New User
Does anyone have an email address or a way to contact?
Dean
Tractor Guru
I would like to purchase pie weights from him, but his profile does not have an email.
Thank you,
J.Walters
I apologize Dean, I have clicked on every button, link, and tag but nothing comes up with your email. Could you email me at [email protected] or please tell me what I'm doing wrong?
Thank you,
j.walters
I'm not at home at this time but will send you an email message when I return, which will be after midnight.
Dean
Email is open on this message.
Dean, it's not showing up on Modern or Classic. Must be in your settings to not show it even though you type it in.
CaryC had that happen a couple weeks ago.
J. - for future needs if you don't see an email button on modern
view, switch to classic view and LOG IN.
Then you should see an email button on Dean's post as circled below.
HTH
for future needs if you don't see an email button on modern view, switch to classic view and LOG IN.
I'm logged in & it still doesn't show.
Wonder why that is? :oops:
(quoted from post at 20:41:54 02/14/14)
Not sure Jon, are you logged in on modern view or classic?
I'm guessing since the quoting worked that you're on modern?
I was & always use Modern but since you said that I logged in thru Classic too. Dunno, wierd.
(quoted from post at 21:48:38 02/14/14)
You could try this if you're curious, go to classic view and post a response.
Just a test reply to this one or something as long as you do it from classic view.
Then see if Dean's email button shows up for you on classic view.
