Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Suggestions Please
Sideways..John,PA
02-14-2014 04:11:46
If'N you wait for 10 inches in depth, you should plan on moving the snow "sideways" across the driveway. Make the path extra wide. as YOU back the blade raise the blade to form the boundary.
You should have skids mounted on the blade to keep the blade 'bout 2 inches off the roadway.
Eventually you will get used to looking backwaards. Keep the blade straight.
Finally reverse the blade and finish up loose ends while going forward pretty fast. Angle blade about 30 deg.
Hope this helps.
John,PA
John Schmincke
02-14-2014 10:54:04
 Re: Suggestions Please in reply to Sideways..John,PA, 02-14-2014 04:11:46
With the house, garage, well and other things on this property, there is no moving snow across the drive. I could in Maryland. I pushed it in all directions a good 50-75ft across the drive out into yard to make room for more later. That worked well. Here I have to push it out of the drive and across the street or distribute it along my fence best I can. No HOA here, just closer than rural.
Copyright © 1997-2015 Yesterday's Tractor Co.
