I'm rebuilding the engine out of one of my 2N's. Plastigauged all bearings (all within acceptable tolerance) and spun the crank after torguing the mains and rods--turned easily. Then inserted the pistons with cast rings in the original sleeves ( honed and crosshatched) and now it takes a breaker bar on the front of the crank to turn it. Each piston was ribbon gauged for clearance and all were within recommended tolerances. The starter cannot turn it!! Other than pulling the tractor in gear or spinning it at the V belt pulley, what can I do to loosen the engine up? Also, checked the ring gaps.
