TractorLinks.com
Show Parts for Model:
Re: N engine rebuilders
Dr. Bert
02-13-2014 17:05:08
JC: Put the pistons in without rings and torqued the caps (all 4 marked prior to removal) and spun the crank. Then, put on the rings and reinstalled each piston, then tried turning the crankshaft and it was very tight. I'm using mineral oil to lube each cylinder and that seems to be helping.
ASEguy
02-14-2014 03:22:16
 Re: N engine rebuilders in reply to Dr. Bert, 02-13-2014 17:05:08
Every time I build an engine I spin the crank with each main cap and/or rod cap installed. Will it spin backwards?
Dr.Bert
02-14-2014 17:15:25
 Re: N engine rebuilders in reply to ASEguy, 02-14-2014 03:22:16
Did that, but not backwards.
pconnie..ks.
02-13-2014 17:22:02
did you clean the ring grooves
Dr.Bert
02-13-2014 17:35:55
 Re: N engine rebuilders in reply to pconnie..ks., 02-13-2014 17:22:02
YES
dbnga
02-13-2014 20:23:31
 Re: N engine rebuilders in reply to Dr.Bert, 02-13-2014 17:35:55
Probably repetitious, but what did you use as assembly lube?
Dr.Bert
02-14-2014 17:14:31
 Re: N engine rebuilders in reply to dbnga, 02-13-2014 20:23:31
YES
