Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: 49 8N Front Dist. rewire no spark UPDATE 2 Now carb question
02-13-2014 13:42:34
needle on side is idle on front is run mix..turn idle screw all the way in..turn it out 1 1/2 turns ...turn run screw in then 2 1/2 out..this is starting point..set throttle about half ..start machine..turn run screw 1/4 turn at a time in .if rpm increases go another 1/4..repeat till rpm decreases..this is lean setting..turn screw out 1/4 turn at a time ..count number of turns..continue out till rpm goes down this is rich setting..turn screw in 1/2 the number of 1/4 turns..this is neutral setting....on back of carb is idle set screw..set it till idle is real slow..move idle mixture needle screw in and out till you get the fastest idle rpm..set idle rpm screw to fast idle.. hth..phil
