TractorLinks.com
Order Ford 9N Parts Online
Re: 9N will NOT Start!
JMOR
02-13-2014 10:41:33
Quoting Removed, click Modern View to seeCompression test can be informative. Wire to feel piston for TDC is "iffy" & you will most likely feel that you can't be sure trying that method. Wire has to be snaked thru hole around edge of cylinder & is subject to movement by valves. Pee poor method. Generally if there is a cam/crank timing problem , it is gross, not just a few degrees one way or another, so simply 'carefully' & as 'slowly' as possible, feel for beginning of compression & then for end of compression. Then look to see if rotor is pointing at least generally toward #1 at distributor. I can give you a full 6 or 7 methods of finding TDC-compression with varying degrees of precision, but most all are too much trouble, take too long, etc. Point is that close is generally good enough, since one cam/crank gear tooth will change ign timing by 16.36 degrees. If gear problems result in such misalignment so as to make it not run, it will likely be large enough that you will eyeball that by observing rotor position. You can try multiple observations until you feel confident that you have a good average that either looks OK or not.
Ray PA
02-13-2014 19:12:52
 Re: 9N will NOT Start! in reply to JMOR, 02-13-2014 10:41:33
Found something interesting on the compression check but it doesn't seem to me it would prevent it from starting. cylinders 1,2,3 hit around 90 psi but 4 was only 35 psi. Obviously problems there but it should still fire on 1,2,3. I will try the autolight plugs but if the H-12s are already sparking I don't see what difference it will make. thoughts??
JMOR
02-14-2014 07:01:12
 Re: 9N will NOT Start! in reply to Ray PA, 02-13-2014 19:12:52
Quoting Removed, click Modern View to seeAgree, should start & run on three, but you will have to address 35 eventually. Different brand plugs won't make a non runner run, but different fresh plugs of any brand might. What are the odds of buying 4 plugs & getting 4 bad plugs? Even if a couple were OK, it would fire. There is more that you haven't found yet, or more likely something that you have declared OK that isn't.
Ray PA
02-15-2014 07:02:36
 Re: 9N will NOT Start! in reply to JMOR, 02-14-2014 07:01:12
OK, thanks to all for the suggestions. One last way out there thought, is it possible the plugs are NOT grounding when screwed in? There is some rust around the plug hole but threads look ok. I'll take the following steps and let you all know:
1. Stiff wire chk for TDC
2. Try adv/retarding timing to limits
3. Spark checker (if I can find one)
4. Wait till Friday (supposed to be 50 deg here, if starts then block heater prob best winter solution)
5. Recheck elec/fuel systems
6. Push it off a Cliff!!
Ray PA
02-13-2014 11:26:04
I'll try the compression check and feel for TDC and get back to you but probably not till tomorrow. Got to go to work now. Thanks all, keep the ideas coming
