Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 9N Parts Online
Re: 9N will NOT Start!
Ray PA
02-13-2014 08:27:22
Yes, good suction at carb when cranking. I could probably pull my hand away but it would take a good tug. I'm thinking more spark timing at this point though because it will not even cough with the starting fluid etc.
old
02-13-2014 08:40:32
 Re: 9N will NOT Start! in reply to Ray PA, 02-13-2014 08:27:22
When was the last time you replaced the plugs?? You have the auto lite 437s in it and are they good and clean. Timing does not just go out and if the points are set right at 0.015 timing should be close enough to run
Ray PA
02-13-2014 11:23:58
 Re: 9N will NOT Start! in reply to old, 02-13-2014 08:40:32
I had the H 12s available. Tried them in 3 days ago. Timing was disturbed due to EI/points swapout.
old
02-13-2014 13:33:58
 Re: 9N will NOT Start! in reply to Ray PA, 02-13-2014 11:23:58
Those H-12s may be where your problems are. I have found many of the Champs now days to be bad right out of the box
Copyright © 1997-2015 Yesterday's Tractor Co.
