Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 9N Parts Online
Re: 9N will NOT Start!
Ray PA
02-13-2014 05:26:04
Thanks Jerry. With the points system installed I've followed the attached Ignition Resistance Test and came up with nominally "normal" results everywhere. I didn't try it while cranking the motor but it seems to me if you go from ign sw to coil (top contact) accross the resistor you should get 3V+ drop. What am I missing?
Also with Elec Ign installed, polarity is reversed by design. ie. neg lead to ign modual (6V) then from coil post through ballast resistor to pos ground. In this case I get 6V at ign modual and 2.75V at top of coil?
I'll try the cranking test but first I have to shovel the new 8 inches of snow to get to the barn!!
Copyright © 1997-2015 Yesterday's Tractor Co.
