TractorLinks.com
Order Ford 9N Parts Online
Re: 9N will NOT Start!
Ray PA
02-13-2014 05:07:54
I've just been jumping the ign sw to eliminate that possibility but given I have good spark at the plugs I don't see how that could be it. Still appreciate the ideas though! Thanks
old
02-13-2014 08:05:16
 Re: 9N will NOT Start! in reply to Ray PA, 02-13-2014 05:07:54
You need a good spark that jumps a gap of a 1/4 inch or more. Compression over 90PSI and fuel. So how is the compression?? How about the air cleaner when was the last time you cleaned it??
Ray PA
02-13-2014 08:12:09
 Re: 9N will NOT Start! in reply to old, 02-13-2014 08:05:16
Good 1/4 inch spark with test plug at each cylinder. Air cleaner probably dirty but right now it is disconnected at carb for troubleshooting. Carb is pulling air in directly from atmoshere.
old
02-13-2014 08:24:12
 Re: 9N will NOT Start! in reply to Ray PA, 02-13-2014 08:12:09
If you put your hand over the air intake of the carb do you get a good suction and do you get gas on your hand when doing so?? Need a good suction there for them to run since that is what pulls the fuel to the plugs
Ray PA
02-13-2014 08:27:22
 Re: 9N will NOT Start! in reply to old, 02-13-2014 08:24:12
Yes, good suction at carb when cranking. I could probably pull my hand away but it would take a good tug. I'm thinking more spark timing at this point though because it will not even cough with the starting fluid etc.
old
02-13-2014 08:40:32
 Re: 9N will NOT Start! in reply to Ray PA, 02-13-2014 08:27:22
When was the last time you replaced the plugs?? You have the auto lite 437s in it and are they good and clean. Timing does not just go out and if the points are set right at 0.015 timing should be close enough to run
Ray PA
02-13-2014 11:23:58
 Re: 9N will NOT Start! in reply to old, 02-13-2014 08:40:32
I had the H 12s available. Tried them in 3 days ago. Timing was disturbed due to EI/points swapout.
old
02-13-2014 13:33:58
 Re: 9N will NOT Start! in reply to Ray PA, 02-13-2014 11:23:58
Those H-12s may be where your problems are. I have found many of the Champs now days to be bad right out of the box
