TractorLinks.com
Show Parts for Model:
Re: Starter Switch
Royse
02-12-2014 15:05:53
Take a look at the top of the button on the old starter switch.
I have seen them get dented or worn off by the linkage.
Then they just don't push far enough to start.
Specially happens with new ones. They don't seem to be as strong.
If that's the problem, you can built it up, solder a washer onto
it etc to make it longer enough to push again for a while.
A new one's not too expensive either, but this may help with
knowing what the cause is so you're not left wondering.
WW2N
02-12-2014 16:48:21
 Re: Starter Switch in reply to Royse, 02-12-2014 15:05:53
Royse, I am throwing this to you as I am not sure if I am reading it right. If you depress the thumb button in neutral does it not also move a rocker to push a rod into another starter button all of which is hidden inside the steering tower. If the rocker is wore down or the 2nd hidden starter button may be at fault?
