Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
grease fittings
tom888fish
02-12-2014 04:36:38
50.133.152.112
Here's a question - I put a grease gun on the zerk of the steering drag link joint and it was really stiff pushing it on. After greasing, I went to remove it and it would not come off. Pulled, twisted and then did what I usually do if they're a bit stiff, rocking it down. And...of course I managed to snap off the nipple. I haven't used that grease gun for quite a while but wouldn't think the coupler would be a problem. However, I'm wondering, is there a difference between modern and 8N grease fittings? Secondly, any suggestions for how to replace the now snapped off on?
[Reply]   [No Email]
Jerrybigrig
02-12-2014 14:47:58
66.87.89.89
 Re: grease fittings in reply to tom888fish, 02-12-2014 04:36:38
Before you put on your nee grease fitting since you said the gun bound up on you what ever you are greasing may have a hardened piece of grease restricting new grease to go in.... What I do is use a propane torch and w the zerk out heat up the area .... Use safety glasses ....keep your face away from the hole because it WILL build pressure and cone flying out &on fire ...if it dosnt come out right away be patient keep heating it will blow out of there
[Reply]  [No Email]
tom888fish
02-12-2014 05:18:35
50.133.152.112
Thanks all for the suggestions!!
[Reply]  [No Email]
jennifer408
02-12-2014 19:51:28
67.142.162.27
 Re: grease fittings in reply to tom888fish, 02-12-2014 05:18:35
when i had that problem i went and grabbed my flat bar (wonder bar, what ever ya want to call it) to persuade it off while i wiggled it around. they can be some stubborn buggers. i can remember a few times, spewing derogatory adjectives at it, while thinking to myself " this is NOT how i wanted to spend my day "
[Reply]  [No Email]
soundguy
02-12-2014 05:01:13
184.240.123.12
many couplers have a rotating adjustment scheme so you can tightent he 3-4 jaws ont he fitting. see if yours does and loosen it.
inthe mean time, tap a ez out into the zerk and extract.
them make a combi tool that has a grease fitting wrench, thread chase and extractor flute.. but you don't need that tool to get them out usually.
if just the tip broke. use a wrench. if it sheared at the threads.. use the extractor.
sometimes an appropriate screwdriver ( flat blade) will drive in and bak them out.
so will a left handed drill bit too.
[Reply]  [No Email]
HCooke
02-12-2014 06:10:05
70.195.64.20
 Re: grease fittings in reply to soundguy, 02-12-2014 05:01:13
One of the few places that an easy out works!
[Reply]  [No Email]
soundguy
02-12-2014 06:35:54
108.112.79.3
 Re: grease fittings in reply to HCooke, 02-12-2014 06:10:05
any really because the hole is already the correct size for the ez out stem.
many times I think people break ez outs because they use too small a flute because they have not enlarged the hole enough.
[Reply]  [No Email]
jennifer408
02-12-2014 19:22:45
67.142.162.27
 Re: grease fittings in reply to soundguy, 02-12-2014 06:35:54
I've got an easy out to actually work maybe 2 times (1 time for sure) in my life, and im 53 yrs old. i remember it vividly because i went running to DH shocked and amazed that it actually worked, he studied it and congratulated me stating that " he had never reached that level of success with one in his life time. and he is 68 yrs old
[Reply]  [No Email]
ericlb
02-12-2014 04:54:04
67.142.161.21
tom also, look at your grease gun, weather it has a hose or your useing the straight pipe it came with ,the coupler on the end is 1/8th pipe thread, you can go to a good auto parts store ang get a lincoln brand coupler to put on it, if these get stuck you can back the jaws off with a wrench and a pliers and remove the gun without breaking the zerk
[Reply]  [No Email]
JCinKY
02-12-2014 04:47:57
64.57.165.186
While there have been and still are different sizes/styles of zerks, I seriously doubt that that make you gun stick.
Some grease guns have adjustable "jaws" in the nipple to grab the zerk, but release it when needed. My cheap grease gun is the same as yours. No way to adjust it and you have to push/pull/twist the thing and hold your tongue just right to get it to come back off.
I would either look for a different gun(if you have the money) or just be patient with your's. I have found that they are all a little different, but usually the same motion gets them off; I rock and twist at a pretty steep angle.
As for getting the broken zerk out, an extractor ( maybe an ez-out) will pull it right out. I shouldn't be rusted in since its surrounded by grease. If that doesn't work, try a left hand drill a size smaller than the body of the zerk. Last resort it just drill and retap. HTH
[Reply]  [No Email]
ericlb
02-12-2014 04:46:23
67.142.161.21
the grease zerks are the same, most of the time when the gun builds up pressure in the hose,and locked the coupler on, either the zerk is plugged or the fitting its on is damaged so the grease cant flow around it, if you have a zerk snapped of the only way to remove it is with the proper size eze out, there threaded, and if you drill it you may damage the threads and then the whole part the zerk is in cant be greases
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
