TractorLinks.com
Show Parts for Model:
Re: OT - wire size
Ken-Pa
02-06-2014 21:09:25
I"ve seen & been involved in discussions like this in my yrs as a contractor . Some people ask but refuse to accept my advice , then yrs down the road I see them having it upgraded by someone else (probably roo proud to ask me) . The distance you are talking about will definitely cause you issues of voltage drop . My advice professionally is to do it right now so that in a couple yrs , you aren"t kicked butt because you didn"t accept experienced advice . I would run no smaller than (3)#6 wires out to your shed & then add an 8" grd rod with auxillry grd from it to the grd bar in your panel .The #6 wires will be (2) hots & (1) neutral connected to a 50 amp double pole main breaker . Then use a 20 amp single pole breaker for the receptacles (which should be grd fault recepts). Then use a 15 amp single pole breaker for the lights . Now the code calls for any receptacle used outside or in an exterior building should be a GFI type receptacle for safety .The extra grd (buried 8" grd rod)is also code & safety . You will not regret the extra expense for materials & time . God bless, Ken
