Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: sleeve puller
farmerhr
01-29-2014 22:56:18
I have had good luck machining up a puck that is .005 smaller than the out side diameter. Then I machine a step that is about 0.003 smaller than the inside diameter and about 0.050 inch deep. Drill a hole for a 1/2 inch theaded rod. Put the theaded rod through the hole and lock it to the puck with two nuts. I push it up through the cylinder and use a couple pieces of steel with a cross piece sitting across them . thread the rod through the hole in the cross piece and then place a nut on the top. As you tighten the nut the rod will pull the puck upward and the sleeve with it.
Hope this helps. I would be happy to try and answer any questions you might have.
