pie weights
GordyMN
I have a set of rear wheel pie weights that I have used on my 8n. Do they also fit the Jubilee and hundred series rear wheels? I don't think they fit the 2n or 9n.
Could someone tell me what tractors they fit?
Thank you.
Gordy MN
They will fit the 100 series and the jubilee the only question is if they are the heavy wt's they won't fit on the power shift wheels.
If they're like my pie weights, they'll fit the 8N/Jubilee(NAA),
100 series and early 1000 series.
They do not fit the 9N/2N.
They may not work with spin out rims, depending on which ones
you have.
I think, although I'm not sure, they will fit the later 1000 series
too as long as they have the 8 on 6 bolt pattern.
Someone may chime in with a more definitive answer.
They will fit any of the smaller Fords with the 8 lug on 6" bolt circle from 1948 till 1983 and some of the Ferguaons as well.
That said, if you look in your owners manual on ballasting your tractor it will give you a maximum weight beyond which more weight is not reccomended.
They did make both a light set of pie weights ~ 400lbs/wheel and a heavy set ~ 550/wheel but neither were recommended for the N and Jubilees.
However, you wouldn't be the first guy who has bolted a Light set on his N or Jube with little or no ill effects.
typically they will fit but Since you didn't say what size rims/tires you have and what size rim/tires you what to put them on,they may or may not fit. Tire/rims get switched around a lot on these old tractors. Best to weigh one of the segments and state the size of rims and if that are going used on a set of PA rims.
Kirk
