TractorLinks.com
Order Ford 9N Parts Online
Re: 9N Won't turn over
old
01-28-2014 16:01:08
You can maybe test it one of a few ways. #1 Use a heavy cable like a battery jump cable etc and go from the ignition side of the battery to the starter. Make 1000% sure it is out of gear. Touch the stud on the starter. If good it should spin the engine over. If all it does is spark it is locked up in the ring gear or bad. If no spark bad or bad ground
#2 remove the starter. Be careful since these starter come all apart if you pull them out with out installing nuts on the starter bolts. Then take it to an auto parts store. Do not tell them it is 6 volts or you might confuse them
