Show Parts for Model:
Re: Lift cylinder and piston
01-28-2014 15:13:39
you can tap the hole that feeds oil to the cyl for a big grease fitting. then fill the cyl with gear oil thru the hole. put grease fitting in.. then pump some grease to it. pretty much has to come out.. that or pop the 4psi hose the grease gun has ( usually ).
post back.
ps. closed end of piston goes into bore. oring first.. backup washer on the back side. oil presses the oring into the backup washer and that into the ring land wall. BU washer protects oring from cutting
cup end of piston faces out for dogbone to ride in
Lisa K
01-28-2014 18:26:23
 Re: Lift cylinder and piston in reply to soundguy, 01-28-2014 15:13:39
That's how he has it stuck in there. I'll post back when we get back out to it. Ice fishing on the agenda this weekend.
01-29-2014 05:51:23
 Re: Lift cylinder and piston in reply to Lisa K, 01-28-2014 18:26:23
let us know.
