TractorLinks.com
Show Parts for Model:
Re: Lift cylinder and piston
LisaK
01-28-2014 10:37:06
He did lube it before trying to put it in. I know he put the neoprene back up washer on instead of the leather one that came with it.
old
01-28-2014 10:39:40
 Re: Lift cylinder and piston in reply to LisaK, 01-28-2014 10:37:06
Which side did he put the o-ring and back up washer?? Should be o-ring in to the cylinder first then back up washer and if back wards might be where the problem is
LisaK
01-28-2014 11:08:48
 Re: Lift cylinder and piston in reply to old, 01-28-2014 10:39:40
Said he doesn't remember now which way it is but he tried it both ways.
old
01-28-2014 11:13:14
 Re: Lift cylinder and piston in reply to LisaK, 01-28-2014 11:08:48
If he did the back up washer going in first it may have rode up on the o-ring and that is why it is now stuck. As for using air to push it out how much pressure is he using and is he sealing the tip of the air nozzle so it gets most of the pressure?? Also remind him to point the piston/cylinder in a safe direction. Sure would hate to here he had a hole the side of the piston in his gut
LisaK
01-28-2014 11:18:50
 Re: Lift cylinder and piston in reply to old, 01-28-2014 11:13:14
I think we've got 2 60 or 80 gallon tanks plummed together im not sure what the output psi is. Well I told him to try the atf. I believe most of the air pressure is going into the cylinder. worked pretty well to get the old one out. Ya they really fly out of there quick If your not careful!!
Bob
01-28-2014 13:34:31
 Re: Lift cylinder and piston in reply to LisaK, 01-28-2014 11:18:50
"Ya they really fly out of there quick If your not careful!!"
That is an UNDERSTATEMENT. Stuff like that has enough force to KILL.
Pumping oil into it with a hand pump would be a LOT safer than compressed air.
Case in point... quite a few years ago we had a trencher with a 12HP Briggs in the shop.
Took the head off and it had a broken rod, with the piston way down in the bore.
I got the BRILLIANT idea to blow compressed air into the crankcase through the breather.
It built up pressure for a few, then, suddenly the piston popped out... straight upwards, past the noses of myself and a helper, hit the foil-faced insulation about 18 feet overhead, and tore a hole in it.
Then, fell down, again right between us, and slammed down on the flywheel shrouding just a few inches from where it took off!
CRAP!
We were darned lucky one of use didn"t get in the face on the way up, or on the head on the way down!
Since then, I don"t use compressed air for such things!
old
01-28-2014 12:09:54
When I do one I try to have it set up so the piston will fly into a pile of rags that are in a bucket laid on its side
LisaK
01-28-2014 11:06:55
Im waiting for him to text me back and answer me on that one.
soundguy
01-28-2014 15:13:39
 Re: Lift cylinder and piston in reply to LisaK, 01-28-2014 11:06:55
you can tap the hole that feeds oil to the cyl for a big grease fitting. then fill the cyl with gear oil thru the hole. put grease fitting in.. then pump some grease to it. pretty much has to come out.. that or pop the 4psi hose the grease gun has ( usually ).
post back.
ps. closed end of piston goes into bore. oring first.. backup washer on the back side. oil presses the oring into the backup washer and that into the ring land wall. BU washer protects oring from cutting
cup end of piston faces out for dogbone to ride in
Lisa K
01-28-2014 18:26:23
 Re: Lift cylinder and piston in reply to soundguy, 01-28-2014 15:13:39
That's how he has it stuck in there. I'll post back when we get back out to it. Ice fishing on the agenda this weekend.
soundguy
01-29-2014 05:51:23
 Re: Lift cylinder and piston in reply to Lisa K, 01-28-2014 18:26:23
let us know.
