Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: How to change hydraulic/transmission oil in a 1952 Ford
01-25-2014 13:12:55
8N's have one common sump for trans/hydraulics/rear end.
There are three drains underneath, one small one on the rear
end, one near the hydraulic pump and one on the trans.
I drain them in that order because it makes less of a mess.
It holds 5 gallons of fluid, so you'll need a big container.
I use Universal Tractor Fluid (UTF) that meets Ford spec M2C134.
You can get it at TSC, Walmart, etc. TSC sells it in 5 gallon cans.
It may only hold 4 1/2 gallons or so if it hasn't been cleaned out.
You can pull the lower bolt on the round inspection cover where
the hydraulic dipstick is, then fill it until it just runs out.
That's the correct level.
If your dipstick isn't marked, you can mark it then.
