Update if ordering Sand Paper
Fuddy Duddy
After posting about using a truing board below I decided to
order a new box myself since it had been over 15 years since my
last order and the supply was running low. I just received my
order. Fast shipping. But I was disappointed that the corsest grit
was 60 and only a small roll of that. The last time I ordered I got
grit down to 18. I called them up and they said they don't get
much of the corse grit anymore. While 60 grit will work, it takes
more work to use it. They said I can order a 10 meter roll 6
inches wide of the 40 grit for $33.95 plus the flat rate shipping
of $7.99. So my recommendation is both a bargain box (still very
useful) and a roll of 40 grit. Might need to call in your order or
look around for the 40 grit rolls.
Sand paper
FD,
After reading the uses for the bargain box of sandpaper I ordered a box on Monday. Received the sandpaper today. Had the same experience with the coarsest grit being #60. It will be quite useful in the shop. It appears to be a high quality product. Thanks for the tip!!
Mr. T. Minnesota
Yes it is good stuff. Not like those packs on paper you buy and fall apart while using them. You can still true your heads and stuff with the 60 grit. Will just take a little more work.
