Foot Throttle Details and Pictures...
wilsonsk
Does someone have good pictures and description of the foot throttle? I'd like to fab my own up but need to know what parts I need to make and where they go.
Thanks in advance!
Steve
Thanks Greg,
I'm really looking for the details on the linkage and how it interacts with the hand throttle.
Can someone that has one installed share installation instructions or good pictures of the linkage?
Thanks!
Steve
(quoted from post at 08:30:36 01/15/14)
Thanks Greg,
Thanks!
Steve
I have one from red rock, just got it. Honestly you should spend the $$ and buy the one from him. Its a great piece.
There used to be sort of a gentlemen's agreement here where no one would post photos of the Zane Thang. The reason being that it was so marvelously simple it could easily be copied and that would be an injustice to Zane's genius and proprietory interest.
I would say the same ought to apply to the repop foot feed from Red Rock. I've met Phil the owner and found him to be a decent, hard working, creative individual. He took an item for which the patent and availability are long gone and brought it back to the market.
That's a good thing and he should be rewarded for it.
If there is money to be made from selling those food feeds and other historic N add ons I hope he makes it.
I personally would not post photos which could only stand to cut into his interest.
I understand the desire protect his interest here, but the reality of it is I'm going to make one myself either way. My approach will always be to do what I can myself and buy what I can't. A large part of that is being raised by depression dirt farmers who's only option was if you break, you make it. I am protecting my own interest by making what I can, spending my time vs. my money, in the interest of spending my money (of which I don't have a limitless supply) on what I absolutely have to (like more tractors). We could say the same thing about every mechanic's shop, they are good at what they do, so we should preserve their interest by giving them our patronage, yet most of us by far do our own work. Many places you can draw this line.
So, regardless if I get any answers here or not, I'll figure out a way to do this and it will work and I will learn by doing so. Just thought I'd ask.
Thanks,
Steve
(quoted from post at 14:40:58 01/15/14)
Thanks,
Steve
Steve,
I think the thing here is "why reinvent the wheel?" I would fancy to wager than unless you value your time at less than $10/hr, the time spent to design and fabricate a working foot throttle will far out weigh the cost of simply purchaseing the one from red rock.
also, if we continue to support red rock, who knows what else he might start manufacturing?
to answer your question, the foot throttle should allow the hand throttle to operate independently (like original) So you would need to design a method for the foot throttle to pull the linkage while at the same time not interferring with the hand throttle
That's a valid point Joe, but I'll counter with a couple things, I do value my time at less than $10/hour in this case, because it's my time, my tractor, not to mention I take a lot of enjoyment out of solving problems like this and taking on a challenge.
Regarding "why reinvent the wheel?", I'll counter that with, who knows what I may come up with in the process of doing this myself that may help everyone as well. If you always do what you always did, you'll always get what you always got.
I get the functional requirements of the foot feed, was just looking for generally how it's done.
I'll also throw in, that like many here, my time is waaaaaaaaaaaaayy more plentiful than my money these days.
Thanks,
Steve
(quoted from post at 15:03:54 01/15/14) That's a valid point Joe, but I'll counter with a couple things, I do value my time at less than $10/hour in this case, because it's my time, my tractor, not to mention I take a lot of enjoyment out of solving problems like this and taking on a challenge.
Thanks,
Steve
Good luck in your endeavers. I have the problem or no time or money, so i have to decide which is more valuable. I'd probably i am one of the younger guys on this site with an N.
as far as you actually designing one, I think the biggest challenge is going to be turning the "push" of a pedal in the "pull" of the throttle.
and a final thought about time- they say given an infinite amount of time a monkey could write the works of shakespeare- but im certainly glad William himself did it first!
Fair enough Joe.
I'll let you know how it goes, my bullheadedness in matters such as this never prevents me from accepting an "I told you so" when deserved. My failures are never the result of not trying. I'll keep you posted.
Thanks again,
Steve
...and in fairness.....this is a bit of a Haiku compared to Shakespeare.....and Bob Newhart tested the theory with the monkees, the amount of time required was not sufficient.
...also, Henry Ford's first endeavor in the auto making industry was thwarted by a group of investors headed by Henry Leland, then-owner of the Lincoln Motor Company.....
In reading your post I'm not sure what tractor it is for. I assume it was for the N tractor? If so I haven't made one for the N tractor so i can't be of help. Should you deside to make your own I hope you will share the information with the rest of us.
Kirk
This is for a '49 8N, and I will post results. I have a 1930 Erskine with both hand an foot throttle, I'll use that as a point of reference as well.
Kirk, what have you made them for?
Thanks,
Steve
Hundred and thousand light industrial series. I have made detail drawing with measurements available for free to members of this site. you can look it up in the ford section.
I was contacted by Phil,RedRock, and I spend him my original so he can produce them.
I will be putting a set on my newly acquired 871 gold demo. I had a set on my 671,841 and 4000 series. They work great on the SOS. Soundguy has a set on one of his tractors as well as other people on this forum.
I have not made one for the N tractor. Even though I still have a half dozen or so of them I don't use them as much as I do the hundred and early thousand series.
It will not interfear with the hand throttle. you can use either or.
kirk
Even though there were no laws broke or patents infringed, I just wish he had shown Zane that same respect.
You are right Jon.
When I posted this morning I hadn't seen that.
I guess I'll just kind of throw my hands in the air and back out of this thread.
Let folks do as they wish.
(quoted from post at 23:46:12 01/14/14) Does someone have good pictures and description of the foot throttle? I'd like to fab my own up but need to know what parts I need to make and where they go.
Thanks in advance!
Steve
ry this . Remove the *
http://www.n*tracto*rclub.com/forums/manuals/messages/3674.html
(quoted from post at 22:15:48 01/15/14)
Hold on, you're maligning Phil unjustly. The position control device sold by Redrock is modeled after one of two devices that were on the market, available to the public, 50 plus years ago. It's NOTHING like Zane's position control device. Zane didn't invent the position control add-on, he just invented his own version of one. Nobody stole his idea. That idea has been around a LONG time.
Wasn't meaning to malign anyone, just seemed like his came along after what we all considered to be Zane's idea.
I stand corrected & apologize for the confusion.
(quoted from post at 09:27:46 01/15/14) There used to be sort of a gentlemen's agreement here where no one would post photos of the Zane Thang. The reason being that it was so marvelously simple it could easily be copied and that would be an injustice to Zane's genius and proprietory interest.
Ditto....
I post many pictures, that I have captured off the web, but detailed instructions/measurements belong to the owner..
i have a home brew one on a prior model rowcrop that a buddy built. he originally built them for an ag model he has and sent me one to adapt it for the rowcrop i have. slight mods.. but works.
yep.. very minor mod at the steering box and running board and that makes a good gas pedal to mow with. :)
Thanks for all of the help!
I have a good supply of info from several folks and I have found a fair amount on the net as well. I have a plan and am accumulating and gathering parts. Stay tuned for pics........
Steve
I also want to apologize if I stepped on toes or didn't appear to show proper respect for people's work. The reality of it is if I want this feature, I need to make it my self, just don't have (or can't justify) the funds right now, and have all but about $7 worth of the materials in my garage (the remaining couple of rod ends I ordered from McMaster) as well as a mill, lathe, band saw, a few welders, etc. Once again, my apologies where I owe them a a huge thanks to all.
Steve
I'm a little confused. Reading back over this thread, I don't see
any mention of anyone misappropriating any of Zane's ideas.
Someone posted asking for info that would help them build a
DIY version of a non-Zane 50 year old device whose patents have
long since expired and whose manufacturer long since
disappeared. How on earth does that hurt anyone? Sure Red
Rock makes a copy (a very nice one, I should add), but that
hardly gives them any moral rights to the design. They also
make a (functional) knockoff of Zane's Thang. So why aren't we
all jumping on RR for treading on his Zane's turf, instead of
acting like RR somehow has moral rights to all the products they
repop?
Personally, I subscribe to the notion that an individual is free to
copy any idea, patented or not, to DIY a one-off , non-
commercial version for his own use.
Steve,
This may be several days/weeks late and and probably more than a few dollars short...
...but send me an email. I've got something that will help you.
Sorry for drudging up the old post.
