Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
cylinder head
Breese
01-13-2014 20:03:16
173.174.46.157
This message is a reply to an archived post by Pajamafied John on June 06, 2012 at 15:56:11.
The original subject was "Re: cylinder head".
I replaced the pistons (and sleeves/rings) in my 1945 2N. The top of the pistons were slightly domed and touched my cylinder head (not bolted down, no gasket).
I'm concerned I may have removed 'too much' cylinder head material as my max compression is only 40 PSI across all pistons. Root cause may lie elsewhere (and I'm troubleshooting that for now) - just curious if removing too much cylinder head metal might be my problem; your thoughts?
[Reply]   [No Email]
ford4
01-15-2014 17:15:51
166.181.82.51
 Re: cylinder head in reply to Breese, 01-13-2014 20:03:16
Very comon problem. There is little clearance between the head and piston and machine work was not very precise back in the 40's and 50's. Therefore removing material from the head and/or block on one engine may be ok while the next one may cause interference problems. There are shims available in different thicknesses to compensate for this. The shim must be against the block and sprayed with copper coat. I have used them and don't worry, they do not leak.
[Reply]  [No Email]
teddy52food
01-14-2014 07:07:54
184.94.175.179
Do anything to the valves? Head is not your problem.
[Reply]  [No Email]
HCooke
01-14-2014 05:25:36
70.195.67.191
" my max compression is only 40 PSI across all pistons"
Could be valve timing. Check timing mark on crank gear and cam gear.
[Reply]  [No Email]
JMOR
01-13-2014 21:18:30
72.181.173.171
 Re: cylinder head in reply to Tom Jubilee, 01-13-2014 20:03:16
Quoting Removed, click Modern View to seeWon't make that kind of difference....you have other problems!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
