I think my spool valve on my Wagner loader went out completly today. When I raise the bucket it quickly dops unless I hold the spool lever in the up position. I braced the buket up and removed the upper hose and then lifted the arm and the bucket fell, no fluid came out of the top hole on the ram. Could someone tell the least expensive spool valve I cn use? Also all of the valves I've seen are set up for double acting cylindrs on each lever. The lift arms are signle acting cylinders. Would someone have a diagram of how I could plum in the replacement valve.
Thanks,
Bill
Thanks,
Bill
