TractorLinks.com
Show Parts for Model:
Re: Stihl Oil mix in Gas
JMOR
01-04-2014 09:22:34
Quoting Removed, click Modern View to seeWife's uncle always said old Farmalls had a habit of sticking valves, so he always put a qt of motor oil in every tank of gas....80:1 mix.
Dean
01-05-2014 06:28:23
 Re: Stihl Oil mix in Gas in reply to JMOR, 01-04-2014 09:22:34
Old Farmalls, e.g., F series, did not have pressure lubrication to the rocker arm shaft, but rather, oil cups on the rocker cover.
Inside the cover was an oil tray lined with a wick having extensions strategically located to drip oil onto the rocker arms.
Such Farmalls also had very weak valve springs.
If one did not fill the oil cups regularly as required and/or keep the wick (extensions) in good condition, valves would promptly stick.
Dean
soundguy
01-04-2014 09:32:51
I do know that on 2 of my 172 red tigers. after I had stuck valves, when I put back together, I went with walmart 10w30 synthetic oil and no more sticky.
it's this wonderfull gas we have I think. and worse in a humid environment like I'm in. the 2 make a bad combo
Maxwell 99
01-04-2014 11:28:25
 Re: Stihl Oil mix in Gas in reply to soundguy, 01-04-2014 09:32:51
I had a valve sticking in my old jeep, it had a new long block with only 5k miles.
Old guy at Napa told me to try marvel mystery oil, 1/2 qt in oil and 1/2 qt in fuel tank.
All I know is that when I started the motor, the valve was sticking, in 30 seconds it stopped and I never heard it again.
MMO is worth its weight in gold to me.
soundguy
01-04-2014 12:02:28
 Re: Stihl Oil mix in Gas in reply to Maxwell 99, 01-04-2014 11:28:25
in a situation where you don't have pushrods to bend.. i don't mind trying some atf in the oil and gas to free up a sticker.. but once ya got bent pushrods.. it's surgery.. :)
