Yesterday's Tractor Co. New Parts for Old Tractors
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Mag-Alternator-gen reset
Mr. T. Minnesota
01-04-2014 09:09:53
68.170.114.158
Forum Members,
Denny O. has given me much info on the FM WW2 mag and pointers on set up. One thing he mentioned is that the generator has to be set on the opposite side of the engine to make room for the mag. Question is- did the generator ever stay on the right side? The reason I ask is when purchasing the mag the used parts guy gave me an additional part that went with the mag. It looks like an idler or belt tensioner that some how is attached to the N. Did this apparatus make it possible to attach it to the standard right side or is this idler meant to be used on the alternate left side? Any thoughts or ideas are welcome!
Again, thanks to Denny for his assistance.
Mr. T. Minnesota
[Reply]   [No Email]
Den N Ms
01-04-2014 14:54:48
184.41.140.124
 Re: Mag-Alternator-gen reset in reply to Mr. T. Minnesota, 01-04-2014 09:09:53
Mr.T Sent you a email
[Reply]  [No Email]
WW2N
01-04-2014 12:50:02
64.187.67.48
I got mag parts and drive from Biewers Tractor Salvage Barnsville MN. He may have what you need.
[Reply]  [No Email]
Mr. T. Minnesota
01-04-2014 13:35:48
68.170.114.158
 Re: Mag-Alternator-gen reset in reply to WW2N, 01-04-2014 12:50:02
WW2N,
Thanks for the info.If I need parts or assistance will contact them. Seems the mag is working at this point. She fires consistently out of number one socket with a yellowish-blue spark. Adapted a fitting to fit the tangs on the drive and spun it with a 14.4v Dewalt cordless counterclockwise in low range. Had to slice the oxidation off the points with an exacto knife and fine sand them with 320 black sand paper. Can not wait to change the ignition over when it warms up-June or July?? Thanks again!
Mr. T. Minnesota
[Reply]  [No Email]
JMOR
01-04-2014 21:30:57
72.181.173.171
 Re: Mag-Alternator-gen reset in reply to Mr. T. Minnesota, 01-04-2014 13:35:48
Quoting Removed, click Modern View to seeYou have to get creative to mount a generator or alternator on the left side of a 9N/2N/early 8N block, since the mounting bosses are not there as they are for the late 8N blocks, but it has been done in more than one way.
[Reply]  [No Email]
JMOR
01-04-2014 09:15:47
72.181.173.171
Mr. T. Minnesota said: (quoted from post at 13:09:53 01/04/14)
Forum Members,
Mr. T. Minnesota
Idler was used to tension the fan belt since there was NO generator.
[URL=http://s192.photobucket.com/user/JMOR_photo/media/Ign/mag_idler.jpg.html][/URL]
This post was edited by JMOR at 09:28:47 01/04/14.
[Reply]  [No Email]
Mr. T. Minnesota
01-04-2014 10:48:30
68.170.114.158
 Re: Mag-Alternator-gen reset in reply to JMOR, 01-04-2014 09:15:47
JMOR,
The illustration helped a lot. The idler I hold must be a newer version, it has a grease fitting on the pulley shaft. Thanks again!
Mr. T. Minnesota
[Reply]  [No Email]
TheOldHokie
01-04-2014 12:54:32
74.110.73.195
 Re: Mag-Alternator-gen reset in reply to Mr. T. Minnesota, 01-04-2014 10:48:30
There is a right angle grease fitting on the one in the picture. The little "eye" in the center is the top of the zerk which provides lubrication for the needle bearing inside the idler pulley.
TOH
[Reply]  [No Email]
TheOldHokie
01-04-2014 09:35:22
74.110.73.195
And good luck finding one!!! Stumpy loaned me this one just long enough to measure and produce drawings for repopping them....
TOH
TOH
[Reply]  [No Email]
Mr. T. Minnesota
01-04-2014 09:34:36
68.170.114.158
JMOR,
Thanks for the quick reply. Did not even consider that as a possibility. Am intending to mount an alternator or generator on the left side as needed. Thanks again for the answer.
Mr. T. Minnesota
Close to 30 below zero tonight with 35-60 below zero wind chill next few days.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
