carlntexas
I needed new valve chamber valves and springs and also was replacing relive valve. I found a pump repair kit on Ebay with these in it for $100 which is less than items bought separate. The piston yokes have an extra piece on them do these go to top or bottom of pump or does it matter? Also the bushing don't have a oil slot is it going to get enough oil? Had to edit this is a 49 8N.
Here is picture new on left
The valve chamber springs are are bigger around but not as strong as original will this matter? I've never worked on a pump and kit was made in India.
