In a previous post you mentioned me coming up to Myersville to plow your driveway. I was doing a little research concerning rebuilding the engine on the 8N and found your website with the sleeve removal/installation tool. Turns out that you are just around the corner from me. I'm up on Pleasant walk rd, little did I know I was so close to YT fame. Anyway, I just got done doing my driveway (first time out of the garage on her own power) and figured I could drive the ol' 52 right on down there. Let me know if you need a hand.
(quoted from post at 13:32:57 01/03/14) In a previous post you mentioned me coming up to Myersville to plow your driveway. I was doing a little research concerning rebuilding the engine on the 8N and found your website with the sleeve removal/installation tool. Turns out that you are just around the corner from me. I'm up on Pleasant walk rd, little did I know I was so close to YT fame. Anyway, I just got done doing my driveway (first time out of the garage on her own power) and figured I could drive the ol' 52 right on down there. Let me know if you need a hand.
Well hello neighbor!!! Feel free to stop by anytime but I'm good on the plowing today unless you have a salt spreader on your 3pt ;-) I plowed earlier this AM with the Kubby but the skim left on top of the asphalt is slicker than hot snot and it was all I could do to get back to the top. I'm trying to decide if I want to chance a trip down with the Ram 4x4. We're on the south-west slope of of Church Hill looking right out at you and get good afternoon sun so I'm hoping it will melt enough bare spots to give me a fighting chance by mid-afternoon!!! Knew I should have stocked up on ice melt and sand....
Give me a ring and we can swap some local gossip - 301.655.0631
TOH
Sorry, no salt up here. That would make a mess of my gravel drive. Maybe one day I'll swing by and check out that shop of yours, looks impressive. Good luck with that driveway, be safe. -Justin.
(quoted from post at 17:33:28 01/03/14) Sorry, no salt up here. That would make a mess of my gravel drive. Maybe one day I'll swing by and check out that shop of yours, looks impressive. Good luck with that driveway, be safe. -Justin.
Had to run to Sam's Club and they had 50# bags or ice melt sitting right in my way as I headed for the checkout. Pretty good price so I threw a couple in the truck just in case Old Man Sol doesn'y get the job done for me. I try not to use it unless I have to - asphalt is expensive to replace....
You the same Justin that does body/machine work on Pleasant Walk? If so I might be in need of your body work services come summer. I think you know my son Chris Allen. If interested give me a call or drop me some email with your contact info.
TOH
301.655.0631
[email protected]
I'm a different Justin. The one that does machine work is just about half way between us. He's a good guy, does good work and his prices are decent. I will probably contact you in the future about getting one of your sleeve tools. Later.
(quoted from post at 23:24:39 01/03/14) After reading the below, I can see a 'play date' coming up, be silly not to! ;^)
The welcome mat is always out and in good weather the shop door is always open. All sorts of visitors walk, fly, hop, slither, and stagger in ;-)
TOH
