Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: help on hydraulic pump rebild
01-03-2014 15:48:34
Can any one tell me what to torque those chamber bolts to I was thinking 55lbs but that aluminum housing scares me.
01-03-2014 16:16:24
 Re: help on hydraulic pump rebild in reply to carlntexas, 01-03-2014 15:48:34
Quoting Removed, click Modern View to seeMay not comfort you, since Ferguson, but the 9N/2N pumps for ford & ferguson were interchangeable, and The Ferguson shop manual (same pump as the Fords) calls for 50-55 ft/lbs. on the valve chamber assemblies and also on the cap clamp bolt on both chambers. 38-45 lb/ft. for the pump base to tractor bolts
01-03-2014 16:57:15
 Re: help on hydraulic pump rebild in reply to JMOR, 01-03-2014 16:16:24
Thanks JMOR I had them at 45 will go to 50 tomorrow. I got the pump back together today and all those India parts fit good. I blew some air in the chamber valves and they seemed to be holding.
01-03-2014 21:17:54
 Re: help on hydraulic pump rebild in reply to carlntexas, 01-03-2014 16:57:15
Quoting Removed, click Modern View to seeWhat part of Texas are you in Carl? We are in a big state.
01-03-2014 17:27:19
You know India is capable of world class engineering and really close tolerance machining when they want to - things like nuclear bombs and ICBM's for example :roll:
