TractorLinks.com
Show Parts for Model:
Re: 2N Rebuild: Low Compression
teddy52food
01-03-2014 07:45:00
If you try to torque on the other tractor, it will tell you nothing as they are (set) and will take a lot to break loose unless you back them off first.. Pull the plugs and put air pressure to each cylinder & see where it goes. Crank breather is rings, carb is intake valves & tailpipe is ex valves.
Breese
01-13-2014 19:51:43
 Re: 2N Rebuild: Low Compression in reply to teddy52food, 01-03-2014 07:45:00
My next step is to check leak down with ~2ml of engine oil in each cylinder.
Any preference between 5W, 10W, and 20W weights?
