TractorLinks.com
Show Parts for Model:
Re: 2N Rebuild: Low Compression
Ultradog MN
01-03-2014 06:42:12
I gotta agree with Hobo;
First of all does it run?
If so then your compression readings are wrong.
Secondly, if it wont run it's likely your cam timing.
soundguy
01-03-2014 14:22:33
 Re: 2N Rebuild: Low Compression in reply to Ultradog MN, 01-03-2014 06:42:12
without knowing more..and a new rebuild.. I'd have to third you and hobo's advice as well.
bad test or bad cam /valve timing.
Britcheflee
01-03-2014 08:11:14
If rings were not offset would that cause low compression? Also wondering if installed without a generous oiling of everything then pressure would be less? - after running a bit maybe everything will seat properly and pressure increase?
